HELP : Integra cluster in EG? Diagram?
Old 06-10-2002, 07:26 PM
DB8
DB8's Avatar
Default HELP : Integra cluster in EG? Diagram?
i already use the search option, but didn't come up with anything, i seen the diagram on HT before, i wanted to swap a Type R cluster into my EG, so please if anyone know the link or the actual diagram, please let me know
Thanks in advance
or email me the diagram at rexchris66@hotmail.com
Old 06-10-2002, 07:53 PM
Canttx's Avatar
Default Re: HELP : Integra cluster in EG? Diagram? (DB8)
hey DB8 hope this helps
teg's blue left side plug (13 pins)
1. blu tach signal
2. grn/org check engine indicator
3. yel/red oil pressure switch
4. NOT USED NOT USED
5. wht/blu charge indicator
6. NOT USED NOT USED
7. yel/grn coolant temp
8. blk ground
9. red/blu cruise (if you have cruise)
10. yel hot
11. NOT USED NOT USED
12. pink maintenance (not used)
13. NOT USED NOT USED
teg's right side blue plug (16 pins)
1. grn/red e.brake signal
2. red/grn high beam
3. grn/yel right turn
4. grn/blu left turn
5. NOT USED NOT USED
6. blk/yel power
7. red/blk power
8. red power
9. blu/red abs (not used)
10. grn trunk switch
11. org vehicle speed sensor
12. NOT USED NOT USED
13. blu/wht low fuel (not used, cant be used w/ out integra gastank and sensor)
14. yel/wht fuel gauge
15. lt grn/red door switch (not used, can be used w/ extra wiring to the doorpins)
16. red/blu seat belt
civic's left side grey plug (12 pins)
1. yel/wht fuel gauge
2. yel/blu vehicle speed sensor
5. wht/blu charge
6. yel/red oil pressure switch
7. NOT USED NOT USED
8. blu tach signal
9. NOT USED NOT USED
10. blk/yel power
11. red/blk power
12. red power
civic's right side grey plug (10 pins)
1. red/grn high beam indicator
2. grn/red e brake signal
5. grn/org check engine indicator
6. blk ground
8. yel hot
9. grn trunk switch
10. blu/wht seat belt
lsismore
01-13-2006 01:14 AM
9sihatch3
09-22-2005 08:18 PM
trooper0641
04-20-2004 07:28 AM
dizzyroc88
14
02-29-2004 11:44 AM
lazyguy
08-11-2003 09:27 PM
Quick Reply: HELP : Integra cluster in EG? Diagram?
