Help - How to take out rear panels in the trunk.. - 96' EJ6 HATCH.
i cant seem to take it out.. im afraid im going to break it.. any 1 got any DIY.. i have hardtime takin it out.. any one know how to take it out WITHOUT breakin the panel?? thanks in advanced..
Re: Help - How to take out rear panels in the trunk.. - 96' EJ6 HATCH. (pinoyboiwonder)
Rear side panels:
You have to take the rear seat out, then there's a few other screws holding it.
Once you take those out, take the speaker grill off and there's another screw there (might as well take the speakers out too) and a few pins in the trunk.
Once you take all of those out, just gently pull on the panels (there are some tabs holding it in place, but they'll pop out easily.
i just need to take out the panel to get access to the rear bumper.. the middle panel wont come out and i dont want to force it out or it might break.. i need to change the gasket on the rear bumper cus thats where its leakin (i believe the vents where the bumper is)
Re: (pinoyboiwonder)
You will have to remove the side panels to get to those vents.
Well... maybe not remove the whole panel, but at lest pry open the rear part.
I believe there's either two or four plastic pins that you can remove using a screw driver.
Then you have to make sure it's not hooded up to the side panels at the bottom.
Lastly, pull on it upward... I think.
Sorry, I can't remember exactly how it goes, it's been a while.
which panels are you exactly talking about/
the small panel in the middle (which will be located rite infront of ur tummy when u are opening ur trunk) is sticking with the car by clips.. so u have to pull that **** out pretty hard.. after that, the two side panels.... you must take about speaker covers, since they will have screws inside of it.. unscrew any bolts u see..
oh by the way you gotta take rear seats out before you remove any panels..
just pull panels and see if they have any screws holding inside.. in that way u will not break the panels.. just do it slowly and carefully.. unbolt anything u see.. that's all i can tell ya
Re: (Spoon-EK9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoon-EK9 »</TD></TR><TR><TD CLASS="quote">which panels are you exactly talking about/
just pull panels and see if they have any screws holding inside.. in that way u will not break the panels.. just do it slowly and carefully.. unbolt anything u see.. that's all i can tell ya </TD></TR></TABLE>\
yes its that small square panel right infront of your tummy when you open the trunk.. it dont wanna budge do i pull it upward or out away from me..
Pull it upward, at your face. It's held on there pretty tight, just get your finger under there and start working it off. You do NOT have to remove the rear seats in order to get this panel off.
Re: (******)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ****** »</TD></TR><TR><TD CLASS="quote">Pull it upward, at your face. It's held on there pretty tight, just get your finger under there and start working it off. You do NOT have to remove the rear seats in order to get this panel off.</TD></TR></TABLE>
He wants to get to the the air vents, in which case, he will have to remove the rear seats, because the vents are behind the side panels (Underneath the taillights), not the little square panel (although this panel has to come off to remove the side panels).
civiceg94
09-08-2008 08:55 PM
