HELP: How much oil for a 1.8 GSR?
New User
Re: HELP: How much oil for a 1.8 GSR? (AzntaggeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzntaggeR »</TD></TR><TR><TD CLASS="quote">wtf!?!? really? i only put 3.5 but when i check my oil level it's fine.</TD></TR></TABLE>
When you drain your oil is the engine warm? Is the oil cap open so the engine has room to breathe and allow the oil to flow?
More than likely you're not draining properly. If not, my mistake...
which motor?
which motor?
New User
Re: HELP: How much oil for a 1.8 GSR? (ejprimo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ejprimo »</TD></TR><TR><TD CLASS="quote">
which motor?</TD></TR></TABLE>
It's appears he drive a Del Sol S? Is that correct. Then 3.5 would sound resonable for a SOHC.
Re: HELP: How much oil for a 1.8 GSR? (AsnRefugee)
3.5, and then set it down and let it run for a bit....check the level and add what is needed cause there is always some that is left inside the motor after it is drained.
Its better to have not enough and add more than to have too much!
TSPeed Factory
Re: HELP: How much oil for a 1.8 GSR? (1999silverhatch)
well it's a b18c1 swap in a del sol s. thanks for the info. maybe i'll go pour another half quart in.
cilvia
01-10-2008 12:38 AM
