Help>>>! h22 swap problem in my 00' si
i have h22a swap in my car 2000 civic si and im running a jumper conversion to obd1. well when is hit v-tech at 5,000 rpm the tach drops to zero but the car is still in motion. and v-tech dont work when that happens. let me know asap... thanks
d
e
x
d
e
x
so yeah...vtec kicks but my tach drops and cuts off like redline like a second later... but this is only when using a stock OBD1 ecu with a jumper harness. But when i use my stock b16 ecu for obd2 it runs fine and dandy
Re: (Project Dex)
Well I would assume that there is your problem. you are trying to use a obd2 distributer with a obd1 ecu. You can narrow that down by syaing that with the obd 2 ecu plugged in it works fine and with the jumper harness and the obd1 ecu it doesn't work. Hope we helped.
Re: (bluevic99)
obd2 distributor runs fine with an obd1 ecu.
If he changed any wiring at the distirbutor and messed something up, it would run shitty with either ecu.
Sounds like a problem with the jumper harness or the obd1 ecu.
