HELP FUEL PROBLEM???
HELP!!! My 1996 Honda civic is having difficulty starting up when the engine is at normal temp. it starts up fine in the morning. Then I start it when engine is warm, the car starts but idles really low like its not getting enough fuel. Then sometimes it dies ...at times I will have to give it some gas and sometimes it starts real low idle then revs up automatically to normal idle. Please any help! im guessing its fuel related? Any suggestions thanks a lot!
Re: HELP FUEL PROBLEM???
You can try a new fuel filter and see if that fixes anything. Could be clogged injectors also.
When did it start doing this? Did you change anything when it happened?
Does the CEL work? When the key is turned to ON(II), the CEL should turn ON for 2 seconds and then turn OFF. The CEL will only remain ON if the ECU has detected a problem with a sensor or its circuit.
does the IAC have anything to do w/ fuel related? i was told to clean that out while back but never did. how do i clean it and where is it located? tahnks bro
94cxhatch
13
06-06-2010 01:24 PM
hair_rice
07-05-2004 07:37 PM
