HELP... engine question reall simple
ok, well i recently blew my engine and found a nother one. my stock one that i blew was a d16y8. the one that im looking at getting is a d16y7. will i have to change the computer and all that stuff or will i be able to hook it up and not have to change anything? can someone please help me. or does anyone know where a d16y8 is for sale... i need a engine
Modified by rickgiblin at 2:36 PM 4/19/2006
Re: HELP... engine question reall simple (rickgiblin)
Your original motor was an SOHC VTEC engine. The y7 is a SOHC non VTEC engine. I'm not sure if you'll need a new ecu or not but more than likely you will.
I think there's a mod u can do to ur ECU to change a stock P28 to see if it does vtec or not, somebody else that knows ECU's will have to tell you for sure tho
Your stock engine is a 1.6L SOHC Vtec. I suggest you look for another Y8 motor. That motor is pretty easy to find. I personally would not swap a Y8 for a Y7 motor, but thats just me.
if your bottom end is all thats messed up, just put the old head, IM, TB, dizzy, and harness onto the new motor, and use the stock ecu. that would be the easiest way to do it. other than that you would need a differanct ecu. it wouldnt be hard to just swap the new one in, but you will be losing HP
Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">I think there's a mod u can do to ur ECU to change a stock P28 to see if it does vtec or not, somebody else that knows ECU's will have to tell you for sure tho</TD></TR></TABLE>
It's not a p28, it's a p2p. The p28 is for the d16z6!
