Distrubtor controls fuel too?
Old Mar 5, 2004 | 11:18 AM
advanracing62's Avatar
Default Distrubtor controls fuel too?
one of my friend's was talking about how some sensor in the dist. will tell the ecm not to send fuel or start if it's bad... does this make sense- I'm thinking not, but I'm having a hard time getting some wiring done and want to try to get any and everything taken care of.
Old Mar 5, 2004 | 11:38 AM
mmuller's Avatar
Mad Scientist
Default Re: Distrubtor controls fuel too? (advanracing62)
the ignitor controls injector firing, so if the ignitor is bad, then injector might not be firing thus giving no fuel.
do you hear the fuel pump primming?do you have fuel pressure?
Default Re: Distrubtor controls fuel too? (mmuller)
no fuel pump prime or pressure
Old Mar 5, 2004 | 12:04 PM
doublejz's Avatar
check to see if you have spark, if you don't have spark or fuel, then you probably have a bad main relay. If you have spark, check the fuel fuse, and still check the main relay to be safe, you may have a bad pump. Worst cause is probably a bad ecu, I have heard of ecu's dying which didn't send fuel or spark to the motor.
Old Mar 5, 2004 | 12:22 PM
Default Re: Distrubtor controls fuel too? (doublejz)
ok here's the stumper- brand new Main relay and ECM (three of em to be exact- all known working) Still no spark or fuel
Old Mar 5, 2004 | 12:44 PM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by advanracing62 &raquo;</TD></TR><TR><TD CLASS="quote">no fuel pump prime or pressure</TD></TR></TABLE>I was gonna say, if the ignition is messed up, then your ECU won't get a tachometer signal, so it won't keep the fuel pump running. But if that were the only problem, the pump WOULD prime. Maybe you've got more than one thing wrong?
Old Mar 5, 2004 | 01:15 PM
Default Re: Distrubtor controls fuel too? (JimBlake)
that could be possible, but chasing it down is getting tougher as things are elminated- is it possible that not all the grounds connected would cause this?
Old Mar 5, 2004 | 02:02 PM
500hpsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">the ignitor controls injector firing, so if the ignitor is bad, then injector might not be firing thus giving no fuel?</TD></TR></TABLE>
wrong! care to try and explain again?
If you really believe this statement, dude you need major help.
I guess if the ignitor controls fuel. then the plugs fires the same time with the fuel.
fuel ignito? or spark ignitor?
Old Mar 5, 2004 | 05:44 PM
Default Re: Distrubtor controls fuel too? (500hpsi)
so.. I've eliminated all wiring issues from underdash to motor harness- what now? It's still the same- Fuse box perhaps?
Old Mar 5, 2004 | 06:05 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by advanracing62 &raquo;</TD></TR><TR><TD CLASS="quote">so.. I've eliminated all wiring issues from underdash to motor harness- what now? It's still the same- Fuse box perhaps?</TD></TR></TABLE>
What year and model? Have you checked your fuses?
Old Mar 5, 2004 | 06:21 PM
Default Re: Distrubtor controls fuel too? (Chiovnidca)
98 LS- Yes I've checked fuses- replaced all of em with new ones to be exact
Old Mar 5, 2004 | 06:26 PM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 500hpsi &raquo;</TD></TR><TR><TD CLASS="quote">
fuel ignito? or spark ignitor?</TD></TR></TABLE>
Let me rephrase, ignitor does not "control" injector firing, but it kinda links the ecu so it knows when. so a bad ignitor might make injector not fire...
nOOw go back to your cage
Old Mar 5, 2004 | 09:14 PM
500hpsi's Avatar
nOOw go back to your cage</TD></TR></TABLE>
some times I'm the biggest ******* that I know; I'm glad that you took it well.
the ecu uses inputs from the crank angle sensor, cam sensor, and tdc sensor. these input are used to determine injector on time and injector duration.
Old Mar 5, 2004 | 09:20 PM
500hpsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by advanracing62 &raquo;</TD></TR><TR><TD CLASS="quote">ok here's the stumper- brand new Main relay and ECM (three of em to be exact- all known working) Still no spark or fuel</TD></TR></TABLE>
does the check engine light turn of after 3 sec? If not check for code. if unable to display code. Check the map sensors referrence voltage and TP - voltage should be 4.8 - 5.0. if not, check all of the power input to the ecu and ground circuit from the he ecu. if it's all good, you will need a ecu replacemen.
Old Mar 6, 2004 | 07:37 AM
ECM is known good
Old Mar 7, 2004 | 07:39 AM
well the only thing that hasn't been replaced as far as wiring goes is the fuse box- that's my last hope
Old Mar 7, 2004 | 11:08 PM
500hpsi's Avatar
Again, does the cel goes off after 3 sec?
Old Mar 8, 2004 | 06:01 AM
cel doesn't even come on
Old Mar 8, 2004 | 07:08 AM
MightyMouseTech's Avatar
Hmm, sounds like a bad power lead to the ECM or a bad ground at the thermostat housing. Did you check the ground at the thermostat housing?
Old Mar 8, 2004 | 07:17 AM
Default Re: Distrubtor controls fuel too? (MightyMouseTech)
yeah, I did- cleaned it and everything- still nothing
Old Mar 8, 2004 | 07:26 AM
Do any of the dash lights go into the bulb check mode when you turn the key? It could be just the ignition switch.
Old Mar 8, 2004 | 07:41 AM
no they do not-
guessing that you mean the abs/cel/seatbelt/ lights
also will note that the ig. switch shows power in acc. and on as well
Modified by advanracing62 at 9:59 AM 3/8/2004
Old Mar 8, 2004 | 10:33 AM
what's the proper testing for the ignition switch?
Old Mar 8, 2004 | 01:22 PM
it's not the ignition switch- tested again- Aok
Old Mar 9, 2004 | 05:25 AM
She's going to Honda today- it seems that no one can figure this out
Yay for me... I did something that stumped everyone
