help with CEL code 9..
Old Oct 13, 2003 | 12:03 PM
jArceo's Avatar
Default help with CEL code 9..
i believe im getting a code 9.. the long and short flashes are very distinct correct?
if so then it is a CEL code 9..
anyways according to c-speedracing its:
CYP Sensor (Cylinder) defective circuit or unplugged / defective sensor
* invalid code for throttle body injection Hondas
** invalid code for V6 engines
i have a 99 civic ex.. where exactly can i locate the sensor?
Old Oct 14, 2003 | 12:43 AM
jArceo's Avatar
Default Re: help with CEL code 9.. (xFlipNotiKx)
CEL is annoying me ahhhhh help me out
Old Oct 14, 2003 | 02:50 AM
97hb's Avatar
G-town in the house . Its probably a cel code 90, tighten gas cap at least 3 clicks, or gas cap integrity is not good anymore.
Old Oct 14, 2003 | 11:13 AM
jArceo's Avatar
hmm possibly.. i remember checkin the gas cap tho.. only did a few clicks
the short flashes are quick? i suppose it could be 9 long flasshes
Old Oct 14, 2003 | 04:25 PM
jArceo's Avatar
Default Re: (xFlipNotiKx)
well i guess it could be code 90 since all the flashes r the same.. anyways should my CEL light go off if its the gas cap cuz it didnt and ive tried numerous friends gascaps..
anyways should resetting my ecu turn it off?
Old Oct 14, 2003 | 04:29 PM
JDM-97CX's Avatar
do u have a haynes manual? if so look in there it will tell you what the code is and it will tell you what needs to be done to fix it.
Old Oct 14, 2003 | 05:02 PM
solo2slocivic's Avatar
pull the back-up fuse to clear it then run the engine and if the ltie comes right back on its most likely a code 9 if the lite doent come back on its prob a 90 due to the fact that a gas cap code is a 2 trip detection code
GsrVtec
Oct 19, 2006 07:33 AM
Nors
Aug 14, 2006 06:53 PM
EuN_TeK
Mar 15, 2004 10:32 AM
AamirCWITR
Jun 25, 2003 01:47 PM
