help: car doesn't start sometimes
i'll try to keep this easy ti understand... basicly, my car starts and is warmed up, then i turn it off at the gas station then i try to start it again it doesn't start... the ECU just keeps on clicking when i crank... and this resets all my clock and radio stations and resets my ECU. I looked into the battery but its fine... still charging, and this only happen twice and both times is when i turn off the car after its warm... can someone give me a hand... engine is stock d16y7 with stock ECU..
someone told me about my main relay but i am not sure what that means hahaha... thanks in advance..
Re: help: car doesn't start sometimes (twoforfree)
bad ground perhaps. check your negative battery cable. and also your other grounds, specifically the one by the starter that grounds to the tranny.
i think once your main relay is gone its gone, not starting sometimes... correct me if im wrong though.
smbignick
08-18-2013 01:47 PM
