HELP!! no start.
Old Apr 24, 2005 | 07:47 AM
highperboi's Avatar
Default HELP!! no start.
I put in a flywheel for my friend and now the car wont start. I could have messed something up when i took of the starter cause i forgot to disconnect the battery. When i went to remove the cable on the starter that is bolted, right when i touched the nut with my wrachet the car made the noise when you leave your key in the car. I then rememberd to disconnet the battery. okay so after its all back together it wouldnt start so i push started it thinking the battery was just dead. it started and drove but like when you gave it some gas in gear the temp gauge would go all the way to hot and the car started to stutter and want to die. after doing it a couple times it died and it blew the ECU fuse. also the main relay was making wierd whining noises but it worked fine when i put it in my car. can anyone help me here??? THANKS A LOT
Modified by highperboi at 9:20 AM 4/24/2005
Old Apr 24, 2005 | 08:00 AM
highperboi's Avatar
ive been reading some other post and some say check starter switch? relay? i dont know where those are. the starter fuse is good. and what are those things in the under hood fuse box that are not fuses. how do i check those?
Old Apr 24, 2005 | 09:52 AM
highperboi's Avatar
okay the problem was i fried the ecu. everytime i use this ecu to try to run the car it burns the ECU fuse. is there a way i can fix the ecu? when i use another ecu its okay.
inaety
Jun 24, 2011 12:57 AM
EnzoSpeed
Jun 7, 2006 12:44 PM
Moe
Nov 13, 2003 08:56 PM
jolt-tsp
Oct 31, 2003 04:17 PM
MachAF
Jan 13, 2003 03:30 PM
