Help Broken Cam cap
Help Broken Cam cap
Hello fellow honda civic owners can you help me on how to remove this cam cap on d16y5 head without removing the whole camshaft assembly ,I broke the bolt hole it cracked and I wanna replace without removing the whole assembly thanks
Re: Help Broken Cam cap
You have to remove all the cam caps with the rockers as a complete assembly. After it is off of the head, you can disassemble it. Hold the cam cap rocker assembly by the ends and be careful not to let it fall apart, because there are a lot of parts.
It lifts straight up. Some of the cam caps have dowel pins which may be stuck. Detach those by prying straight up. The camshaft and the oil seal will stay with the head.
The cam caps are machined with the head by a machine that bores the cam bearing holes through both the cam caps and the head. It's a matched set. Cam caps are not sold separately. You will need to repair the one you have or replace the whole head or consult with a machine shop for other possible options.
coot_er
09-20-2004 07:56 PM
