Help! brakes went out!
Now, for the optional **** that WILL make a difference in braking and mostly pedal feel:
1994-2001 GS-R, LS, RS, any Integra brake booster. This bolts into any 1992-1995 with ease. BOLTS right in.
Integra RS master cylinder. The base model RS Integra had NO ABS so the lines match up PERFECT with any non-abs Civic - which most of you have. I have done this in my own car and it truly bolts in.
The Integra master cylinder is a 15/16th whgile the Civic non-abs uses a smaller 13/16th master cylinder.
Finally, add the GS-R, LS, RS, etc. proportion valve and you will have completed the package. 1992-1993 Civics will require you to change JUST the bracket over - use the Teg prop valve with the Civic bracket. 1994-1995 Civics can use the Integra bracket.
I got all this from another post. My civic has abs so can i use the master cylinder from an Integra LS and the brake lines fit? I need to drive my car by tomorrow so i need to know asap! thank you!
1 Post
Re: Help! brakes went out!
The MC might not match up if it's out of an LS. If I'm not mistaken, all LS's have ABS. My LS's MC has a hole behind the reservoir that is straight out to the right side and the other is angled up at a 45 degree or so toward the driver side shock tower. Hope that helps
yeah went to the floor and then i pumped like 3 times then i got whiplash. Then after the whiplash i pressed again and they went straight to the floor.
kuja396
06-02-2008 05:27 AM
Cyrus4g63
03-10-2006 08:35 AM
jboy08
09-02-2005 12:59 AM
Tbindas
06-08-2005 08:30 PM
