Help, adjusted valve springs on my car and now it won't start
I adjusted the valve springs on my civic and now my car doesn't start. Just the starter goes and nothing else. What happened? If I over tighten the valves springs, will that cause my car not to start?? How tight should my valves be??
Re: Help, adjusted valve springs on my car and now it won't start (Old91CivicGuy)
I'm a little confused, you adjusted your valves, but don't know how tight they should be? how did you adjust them?
Make sure to rule out all the dumb stuff like, forgot to plug the spark plug wires back into the distributor and what not....your valves would have to be pretty fugged to keep the car from starting....please outline the process you used
Guest
Posts: n/a
New User
i agree with that guy up there. check helm's manual. there should be conversions and instructions on it man. i kinda get impatient once in a while too, so i get stupid also. so take a note, if you're doing it yourself, take more precaution. if nothing esle works, rely on a handyman(trusty mechanic).
payce
payce
NEEK94LS
20
11-11-2014 02:13 PM
dcomer04
14
05-02-2008 02:35 PM
swapped95
19
09-30-2007 06:29 PM
