Headlight Ground? Would like to know asap.
Where is the headlight ground located? Is it wired to the ECU or is it an external ground? If it is an external ground where is it located. Please let me know asap if you know. Thanks for your help.
Re: Headlight Ground? Would like to know asap. (Threads)
Lt headlight : G202 next to the washer fluid and ps fluid reservoirs next to a brown 1-pin connector
rt headlight: g201 right underneath the top of the radiator support to the rt of the right headlight connector.
Re: Headlight Ground? Would like to know asap. (Echo7847)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Echo7847 »</TD></TR><TR><TD CLASS="quote">Lt headlight : G202 next to the washer fluid and ps fluid reservoirs next to a brown 1-pin connector
rt headlight: g201 right underneath the top of the radiator support to the rt of the right headlight connector.</TD></TR></TABLE>
Are you referring to the wires?
If so, I know where the wires are, but I am not sure where they end. I need to know where the ground connects to....One side connects to the headlight the other side connects to "what i am trying to look for".
Hopefully I am clear in my statements....
Your info helped one of my headlights. I appreciated your help. Thanks a bunch.
pliskin679
01-27-2013 03:40 PM
