Head gasket or what???
Old 01-07-2006, 08:23 AM
AcidFr33ze's Avatar
Default Head gasket or what???
First off I have done the research and I have not been able to come to any conclusion with my problem, looking for some suggestions...
Let me describe what is going on...
I have a 93 civic dx, stock, 1.5 L
My car over heated a month ago. The radiator leaked and the thermostat was fried. I replaced the radiator and replaced the thermostat.
I bought a fail-safe thermostat, and now it is locked open. Let me explain why:
My car overheated from what I believe is lack of coolant in the system. My car burns coolant.
So what I did was a compression test today. The compression came out to be 200 across the board. So I do not know if the head gasket is blown. From my research it is not blown.
Also let me explain the coolant being burned. I see white smoke mostly when I am at idle. So every 200 miles I add about a pint of coolant into the system.
And when I turn on the car with the radiator cap off, I see bubbles constantly coming up (also possible head gasket being blown symptom?????)
Any suggestions to what my problem is, is it the head gasket? Anything else I can do to test??
Meaningful suggestions greatly appreciated, thanks for your time guys ...
Also there seems to be oil in the coolant, since the coolant overfill tank is a brownish color. As for the head, under the oil cap, there is no white foamy substance (hence no coolant buring in head???)...
Andy
Modified by AcidFr33ze at 1:01 PM 1/7/2006
Old 01-07-2006, 09:05 AM
turbod ek's Avatar
Once you overheat a car i would change the head gasket and get the head checked out so it aint warped.
Old 01-07-2006, 10:23 AM
robert_v's Avatar
its your head gasket. try filling up the radiator and if the coolant starts getting pushed out then its your head gasket. i just recently experienced the same problem
Old 01-07-2006, 10:33 AM
gray_civic_coupe's Avatar
Default Re: (robert_v)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by robert_v &raquo;</TD></TR><TR><TD CLASS="quote">its your head gasket. try filling up the radiator and if the coolant starts getting pushed out then its your head gasket. i just recently experienced the same problem</TD></TR></TABLE>
I face the same problem and i think its my gasket
Old 01-07-2006, 10:43 AM
AcidFr33ze's Avatar
The coolant does bubble and get pushed out, which I have read here to be a symptom of a head gasket. I just want to know how come the compression test was the same on all cylinders. I thought that if the head gasket/ or even head are going bad, then the compression test would differentiate between cylinders (&gt;10%).
Any thoughts HT?
Old 01-07-2006, 07:18 PM
AcidFr33ze's Avatar
Default Re: Head gasket or what??? (AcidFr33ze)
::BUMP::
squinn92
Honda Civic (2001 - 2005)
03-12-2016 01:46 AM
thewrai6th
02-08-2013 02:11 PM
JTCdudeman
09-24-2005 07:23 PM
CNSK
09-07-2005 06:33 AM
whagkangmakulet
09-23-2002 08:32 AM
Quick Reply: Head gasket or what???
