Head gasket change .. still smoke
Old 08-09-2012, 09:17 PM
FTNW's Avatar
Default Head gasket change .. still smoke
D16a6
Changed the head gasket about two weeks ago
My car is burning oil, which i will do a leak down soon to figure out.
But what i dont get is why im still getting so much white smoke, My oil and coolant both look normal with no mixture of the two.
my radiator is not showing any sign of fluid lose ..
What else could be causeing the white smoke ?
Old 08-09-2012, 10:19 PM
EK9
Dc4LsTeG's Avatar
Default Re: Head gasket change .. still smoke
Valve seals. Is it at wot, idle, or decel?
Old 08-15-2012, 11:02 PM
FTNW's Avatar
wot ?
From what i can see ( out my rear view mirror ), the smoke starts after stops, and shifting into 2nd 3rd and less at 4th.
If the car idles for longer, more smoke when taking off.
The valves looked pretty crusty when the head was off ( I whitish color) But i was told there fine.
Old 08-15-2012, 11:03 PM
FTNW's Avatar
Im guessing your right, it probably is the valves. Just want to make sure before i swap heads. might as well upgrade to a z6.
Old 08-15-2012, 11:04 PM
FTNW's Avatar
smokes alot when starting up too
Old 08-16-2012, 06:17 AM
JuggerNaut-CTR's Avatar
Originally Posted by FTNW
wot ?
wide open throttle
Old 08-16-2012, 04:16 PM
19civiccoupe99's Avatar
i just replaced the pcv valve i though i had a bad head gasket. take your pcv valve out and shake it and see if the ball moves freely
Old 08-16-2012, 08:05 PM
FTNW's Avatar
What does the pcv valve look like and how do i remove it ?
I know its around the oil filter right ?
Old 08-17-2012, 04:03 AM
here you go http://www.clubcivic.com/board/showthread.php?t=68638
Old 08-17-2012, 07:59 AM
suldy's Avatar
looks like a few things have been brought up already that are most likely the issue.
valve guides
valve seals
pcv assembly (could be black box, o-ring, but most likely ball bearing inside pvc hose)
worst case scenario is your rings are toast. but lets hope its a pvc issue since that would be the easiest fix.
Malt-liquor
12
04-11-2018 06:29 AM
2001tegy
09-12-2009 01:00 PM
tbuck23
04-26-2007 05:10 PM
EF9 JAMS!!!
08-07-2006 05:18 PM
JAPCIVIC R
01-08-2004 05:16 AM
Quick Reply: Head gasket change .. still smoke
