head gasket?
head gasket?
So I have a B16A2 in my 93 del sol, i have the b16 ECU and everything. So my car only does 16.2 in a 1/4 mile, so i did a compression test and a leakage test in each cylinder. My compression was at about 150 for all the cylinders, but with only 4-5% leakage. So i know its not my rings and its not my valves. When performing a wet test the compression did go up about 20-30 psi. However I am missing both the knock sensor and the O2 sensor. Would the knock sensor be screwing things up that badly? Do I need a new head gasket maybe? I know the O2 is making me run rich but wouldnt hurt my power that much. Any ideas on what the problem is or what i should do would be great thanks.
