what is the problem?
So I have a B16A2 in my 93 del sol, i have the b16 ECU and everything. Its always been sorta sluggish, so i did a compression test and a leakage test in each cylinder. My compression was at about 150 for all the cylinders, but with only 4-5% leakage. So i know its not my rings and its not my valves. When performing a wet test the compression did go up about 20-30 psi. However I am missing both the knock sensor and the O2 sensor. Would the knock sensor be screwing things up that badly? Do I need a new head gasket maybe? I know the O2 is making me run rich but wouldnt hurt my power that much. Any ideas on what the problem is or what i should do would be great thanks.
Re: what is the problem? (sick93sol)
well dude.. im pretty sure it is in that sluggish mode when something needs to be replaced/fixed/installed. I would first get that stuff put in (o2 sensor, knock sensor) because the knock sensor might actually be able to trigger it to go into that mode. anybody else?
Re: what is the problem? (team_exceed)
my theory is that since the knock sensor is missing completely, the ECU thinks there Is a knock so its retarding my spark to prevent detonation. Not sure if that's how it works though
your compression is still kind of low and also u meant p30 ecu right ? if know sensor is missing .CEL will come on and the car will idel a bit weird. not too much.just a bit. i would say u either bypass knock sensor or get a chipped ecu to get rid of knock sensor detecting.
not having a knock sensor will retard ur timing and it really screws with stuff and running rich will slowly fowl out ur plugs and getting a chiped ecu is not a bad idea i get mine from this guy J-K-tuning.com
Re: what is the problem? (ls98hatch)
thanks appreciate it, but I would still like to bypass the KS to see if that is the problem. How do I do that? Also would the KS be affecting my compression?
getting a chipped ecu will bypass it not sure what program will do that just ask the john kerr from J-K-tuning.com and he'll set u up with the rite base map program. i dunno if ur familiar with uberdata? and the knock wont have anything to do with compression on the engine. i read u did a wet test and it did shoot up in compression usually means bad piston rings (where did u get ur motor from?) check ur plugs too. check to c if the electrode is covered in oil if so u mite have bad valve seals but since u did the wet test and the compression did go up its more then likely your piston rings
