head gasket
head gasket
iight i just put a swap in and theres alittle lick by the head gasket, i was wondering if it is nessacary to replace the head gasket right away or can i just put some rubber selient on it for now till i get some cashe to replace it
Re: head gasket (gsrHB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrHB »</TD></TR><TR><TD CLASS="quote">does anyone got like a photo guide on how to change a head gasket so i can it as a reference</TD></TR></TABLE>
jdmlyfestyle.com
jdmlyfestyle.com
Re: head gasket (SiYouLater)
dont change it yet. it could just be some oil got spilled and rested near the headgasket. If you did not remove the head or anything there should be no reason why that headgasket is bad. If anything do a compression and or leakdown test.
compression or leakdown wont tell you if the HG is leaking oil, that will only tell u if the coolant rings on the HG are broken, but you'd know if that was the case.
