Half shaft bolts stripped motors in car can I helicoil
Please help my motors in my car an I need to get this done really dont want to remove motor to do it! What can I do all 3 bolts need to be helicoils can I fit a side angle drill has anyone done this while the motors in car?
-Intl Steve Krew
Re: Half shaft bolts stripped motors in car can I helicoil
Windfally Cordless Right Angle Drill Adapter 90 Degree Drill Attachment Right Angle Bend Extension 90 Degree Professional Soild Metal Chuck Drill Adapter with 9.5mm 3/8" Shank
you would want something like this, but I believe you need a half inch shank, not 3/8”.
Whatever you do, just go slow.
You could try lowering the motor to gain enough clearance...worst case, undo everything and pull it out...
There are some right angle drills on the market that should fit the space restraints. Also instead of helicoil you should check out Time-sert. Heli coils dont even compare. Time-sert is pricey but its a strong permanent repair. Its a threaded steel insert that ends up being stronger than the factory aluminum threads. And you dont have to worry about it coming out if you take the bolt out like a helicoil.
-Intl Steve Krew
pro tip, measure the depth of the bolt (to the mating surface of the head) and put some tape on your drill bit at that depth. Don’t go passed the start of the tape and you won’t go to deep!
-Intl Steve Krew
You can put the drill bit in a tap holder and turn it by hand. The metal is aluminum and you're not removing much. Going at it freehand with a power drill can cause damage.
MeanGreenEG9
01-13-2003 08:17 AM
FUP23
08-03-2002 09:35 AM
