H22A into 96' hatch
H22A into 96' hatch
Hey guys has anyone done this yet onhere. We finished the swap and the car rolls out but the idle is very high. It also feels like the car even when the clutch is disengaged is still pulling when your coming to a stop. Also I can get into gear and get the rpm up a little and on a flat surface the car will hold a steady 20mph without touching the gas pedal. Any thoughts or help would be appreciated!
Thanks
Thanks
you could
A)try unplugging your idle air control valve on the back of the intake manifold
B)Mess around with the idle screw on top of the throttle body
C)Try loosening the throttle cable a hair, sounds like it may be too tight.
Good luck.
Good luck.
Krnbk2
09-12-2004 09:35 PM
