h22 is starting to grind?? cant determine what is, need help!!!!!
ok cant really figure out why it started to do this. there was a leak in one the lines to the slave cylinder so i fixed bleed it and took it out for a drive and it grinds from 1st to 2nd and 3rd to 2nd. while in nuetral i can go into every gear perfect and when in second gear i can go to 7k no problem no popng out. so what could it be. as ive been reading ive read it could be the sychro, but just to do that out of knowhere, also been reading that the clutch master cylinder needs to be adjusted dont think so but its an idea, change the throw out bearing which did start to squeel, and to change the fluid to Pennzoil Syncromesh or oem fluid
any help id really appreciate it
thanks
thanks
Re: h22 is starting to grind?? cant determine what is, need help!!!!!
syncros and maybe your slider h22 trans are known for this ive replaced a few syncros and sliders and even gears in the past
boostedNOTHARDLY
10
09-25-2009 08:36 AM
