h22 96civic ex with codes 4,21,36
Re: h22 96civic ex with codes 4,21,36 (jlacoy82)
ok thanks but i already know what the problems are i just dont know how to fix them here are the codes
4 CKP - crank position sensor
21 VTEC spool solenoid valve
36 traction control found on JDM ecu's
PLEASE HELP
PLEASE HELP
Re: h22 96civic ex with codes 4,21,36 (vtec420kingH22)
4 - check or replace distributor
21 - check or replace VTEC solenoid
36 - just leave it. haven't heard of it and I'm sure you probably don't have it
Re: h22 96civic ex with codes 4,21,36 (EKhothatch)
i posted this same thing on another forum and they said the 36 is from jdm ecu's...which i have..that shouldnt matter then?
Re: h22 96civic ex with codes 4,21,36 (Braco11)
ok so whats the first one i should worry about? code 4 huh.....how do i make sure i need a new one...
Look in the manual how to test it. Check the guts of the dist and the wiring. I had TDC code on my z6 and to fix it I ended up have to get a new z6 dist. I tested and did everything I could nothing would fix it besides a new dist.
CYL code could be a misfire too. Does that cyl have good compression?
Godflash
12-14-2004 05:28 AM
hondaZvic
11-09-2003 01:16 PM
