Is this a GSR tranny?
Old 03-24-2006, 06:08 PM
hondachris1994's Avatar
Default Is this a GSR tranny?
http://www.jprmotor.com/produc...id=31
or a LS tranny and will it fit on any B-series?
Old 03-24-2006, 06:56 PM
Ruben19's Avatar
i think the gsr tranny is the Y80 or S80
not sure but every B-series tranny will fit any B-series block.
Old 03-24-2006, 07:06 PM
professor poon's Avatar
Default Re: Is this a GSR tranny? (hondachris1994)
contact the vendor...
Old 03-25-2006, 03:12 AM
anyone know?
Old 03-25-2006, 03:38 AM
Is it a type R tranny?
Old 03-25-2006, 05:02 AM
Buggee's Avatar
well ya B series trannys are made for B series motors
Old 03-25-2006, 05:23 AM
Default Re: (Buggee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Buggee &raquo;</TD></TR><TR><TD CLASS="quote">well ya B series trannys are made for B series motors</TD></TR></TABLE>u cant read someone already said thanx for the bump though....anyone else no?
Old 03-25-2006, 05:35 AM
pdiggitydogg's Avatar
you cant tell from the outside.....
the only way I know is to count teeth or look at the bearing differences on the diff
Old 03-25-2006, 06:50 AM
Default Re: (hondachris1994)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondachris1994 &raquo;</TD></TR><TR><TD CLASS="quote">u cant read someone already said thanx for the bump though....anyone else no?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by professor poon &raquo;</TD></TR><TR><TD CLASS="quote">contact the vendor...</TD></TR></TABLE>
No, looks like YOU can't read. Email the ******* vendor! How are we supposed to know?
Old 03-25-2006, 07:12 AM
Default Re: (professor poon)
No, looks like YOU can't read. Email the ******* vendor! How are we supposed to know?</TD></TR></TABLE>Maybe someone has this tranny u (professor poon) jackass!!!!!! like I said anyone know what tranny this is? I already emailed vendor no reply
BTW this is honda tech not asshoile tech (professor poon=*******)
Old 03-25-2006, 07:24 AM
HEY
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">you cant tell from the outside</TD></TR></TABLE>
It doesnt matter what the hell the casing looks like...you have to open it to identify the thing
LOTS of people have b series transmissions....and everyone will tell you, they ALL look the same
Old 03-25-2006, 07:31 AM
Default Re: (pdiggitydogg)
Does DC2=integra type R? because it says JDM INTEGRA DC2 tranny?
Old 03-25-2006, 07:49 AM
skunk2eg's Avatar
DC2 = 94-00 integra in general
Old 03-25-2006, 08:21 AM
D.Dappa's Avatar
Default Re: (Ruben19)
other than being able to tell if its cable or hydro all B-series transmissions look the same the only way you can tell is from te tranny badge or checking stuff inside. no one here will be able to tell from those pictures and if your vendor wont respond to your emails maybe you shouldnt buy from them...
Old 03-25-2006, 08:25 AM
Default Re: (D.Dappa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D.Dappa &raquo;</TD></TR><TR><TD CLASS="quote">other than being able to tell if its cable or hydro all B-series transmissions look the same the only way you can tell is from te tranny badge or checking stuff inside. no one here will be able to tell from those pictures and if your vendor wont respond to your emails maybe you shouldnt buy from them...</TD></TR></TABLE>I wasnt gonna buy it until I knew for sure what tranny it is,thats y i posted this thread 2 see if anyone knew or not....thanx for all the feedback
Old 03-25-2006, 08:32 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondachris1994 &raquo;</TD></TR><TR><TD CLASS="quote">Maybe someone has this tranny u (professor poon) jackass!!!!!! like I said anyone know what tranny this is? I already emailed vendor no reply
BTW this is honda tech not asshoile tech (professor poon=*******)</TD></TR></TABLE>
lol good one.
Old 03-25-2006, 08:35 AM
lol good one. </TD></TR></TABLE>Thanx
Old 03-25-2006, 10:44 AM
turboxsi's Avatar
The back up light switch is not in the stock location, usually located under the shifter arm on most b-series cable trannies (usually the d-series have the back light switch on top like the one in the pic). And most b-series cable trannies I have seen (I had a ys1 in my 93 da, as did my friend with a 93 gsr) the speedos are cable driven not electric like the one in the pic. The clutch release arm (arm connect to clutch cable) is one flat piece of metal, whereas the b-series arms are steel bent into a ~1/2" by ~1/2" hollow square shaft. And you can make out the L3 on the bell housing tag, too. Haven't seen that before either. Someone correct me if im wrong, b/c i am just going off what i have seen in the past.
Just my .02 but i think the hydro tranny in the two pics is some sort of b-series (94-up), but the cable definitly not b-series.
Modified by turboxsi at 3:00 PM 3/25/2006
Old 03-25-2006, 10:52 AM
Default Re: Is this a GSR tranny? (turboxsi)
the top 3 pics are a cable tranny, and the lower 2 are hydro
Old 03-25-2006, 10:55 AM
turboxsi's Avatar
i just realized that there are different transmissions in each pic my bad. Two are hydraulic and the other cable....seems shady to me b/c they call them all the same transmission. But it shows what i am talking about below with the back up light switch.
Plus the dude can even spell hydraulic right....
Old 03-25-2006, 11:56 AM
2000EM1's Avatar
bahwhahahahaha captain obvious post of the year right there, fellas.
Old 03-25-2006, 12:00 PM
Sketch_hs's Avatar
those pics suck
CMurphy63
06-09-2008 11:07 AM
big_dong861
01-12-2008 09:00 AM
slammed95lude
04-17-2007 03:22 PM
spazz0nater
08-30-2005 03:18 PM
h22a92accordex
05-23-2005 08:40 AM
Quick Reply: Is this a GSR tranny?
