gsr swap into 95ex
Old 07-31-2005, 07:15 PM
Honduh@Love's Avatar
Default gsr swap into 95ex
im lookin to swap in a gsr into my 95ex. should i go with the gsr tranny or wil a b16 tranny bolt up to it? does anyone no where i can find a gsr motor other than junkyards? and is there anyone in MD who would help me with the swap?
Old 07-31-2005, 07:19 PM
BROKE.eg's Avatar
Default Re: gsr swap into 95ex (g5civ05)
i have a gsr swap with the gsr tranny. it pulls good but the b16si tranny has shorter gearign so it would accelerate faster. any bseries tranny will work with any bseries block.
Old 07-31-2005, 07:20 PM
IgoTSol's Avatar
you dont want a jdm?, i wouldnt have a clue if they sold US ones online
Old 07-31-2005, 07:31 PM
Ragecloak's Avatar
http://www.hmotorsonline.com
http://www.sohfast.com
http://www.ebay.com
b16a tranny is a good choice, but i believe it has a lower top end...how much lower though, i dont know. But yea, it should bolt right up
Old 07-31-2005, 08:03 PM
crazi92hb's Avatar
Default Re: (Ragecloak)
i have a b16 swap in my car and i had a s80 tranny and ran a 14.1 all motor then after i finally got my hands on a s4c tranny i ran a 13.65. if you can get a b16 tranny i would definitly use it cuz thats what i run o n all my cars.
Old 08-01-2005, 08:50 AM
thanks for all your input everyone. about goin jdm, i will if i can come across one thats not to terribly out of my price range. and i no being tight with money isnt exactly the way to go into a swap situation, but im also not lookin to spend piles and piles of money you no? thanks again every1.
Old 08-01-2005, 08:54 AM
B18CR_EJ2's Avatar
Default Re: (g5civ05)
yeah the b series trannys are interchangable and the b16 has shorter gears for better acceleration but also poor highway driving.... about 4500 at 70 mph but its up to you.... call japan direct to get jdm gsr and b16 tranny.... 1-888-518-7341. good luck
Old 08-01-2005, 09:13 AM
what makes a jdm motor the way to go over a usdm? the numbers they produce or am i wrong?
Old 08-01-2005, 10:31 AM
Ragecloak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g5civ05 &raquo;</TD></TR><TR><TD CLASS="quote">what makes a jdm motor the way to go over a usdm? the numbers they produce or am i wrong?</TD></TR></TABLE>
they say it's because the way the motors are built for the japanese consumers...apparently, they have a higher quality of gas over there, so the engines are tuned to be able to take advantage of that...pretty much every jdm vs usdm motor that i've seen, the jdm one has a higher compression ratio
Old 08-01-2005, 10:41 AM
I Deliver
EJAYATE's Avatar
No one has said the ITR tranny, I believe that has shorter grears than the gsr tranny. Make sure you get one with a lsd
Old 08-01-2005, 11:45 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ragecloak &raquo;</TD></TR><TR><TD CLASS="quote">
they say it's because the way the motors are built for the japanese consumers...apparently, they have a higher quality of gas over there, so the engines are tuned to be able to take advantage of that...pretty much every jdm vs usdm motor that i've seen, the jdm one has a higher compression ratio</TD></TR></TABLE>
ahhh i seee now. thank you for clearin that up for me.
Old 08-01-2005, 11:47 AM
Default Re: (B2CivMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2CivMan &raquo;</TD></TR><TR><TD CLASS="quote">No one has said the ITR tranny, I believe that has shorter grears than the gsr tranny. Make sure you get one with a lsd </TD></TR></TABLE>but are itr trannys harder to find/ more expensive?
one2race
15
03-17-2007 12:23 AM
richboi
09-30-2006 05:35 PM
kpop
13
07-16-2006 01:42 PM
pyrus
11-09-2005 08:32 PM
Quick Reply: gsr swap into 95ex
