GSR seats
Old 04-14-2011, 08:46 PM
si_23's Avatar
Default GSR seats
How come GSR seats don't fit fully into a civic? I gotta 2000 civic si. Also does civic seats fit into integras? thanks.
Old 04-14-2011, 08:51 PM
j4s0n1337's Avatar
Default Re: GSR seats
If they're from the same year range, they should fit. If not you can always swap the rails on the seats
Old 04-14-2011, 09:33 PM
Ultracoupe's Avatar
you can change your rails of you si seats to the gsr seats and they will bolt in
Old 04-14-2011, 09:38 PM
Crazy Honda Guy
Deetz's Avatar
No, they don't fit if they are the same year
All 94+ integra seats have 3 bolts that line up, the inner rear does not. Simply swapping your stock inner rail for each seat makes this a direct bolt in. There are many threads that cover this subject
Old 04-15-2011, 10:50 AM
sanchez63636's Avatar
i recently did this...
yes only 3 bolts line up. also what alot of places dont tell you is that if you only swap in the inner rails your seat will lean... its super easy to fix though. just swap the whole inner rail and for the outer side just swap in the slider part. there should be 3 bolts holding it in place. ill admit its confusing at first but after that it took me like 5 mins for the other seat.
Old 04-15-2011, 11:00 AM
LoLoCivic's Avatar
yeah `best thing to`do is swap sliders
Old 04-15-2011, 11:18 AM
another thing to keep in mind is that integra seats sit lower. i believe its 3/4 to 1 inch lower?
Old 04-19-2011, 06:16 PM
si_23's Avatar
So then would si seats fit and into an integra if I just change the rail? What I'm trying to do is get some GSR seats and give my brother some custom made civic seats. Should I just swap rails for both seats and then plug and play? help thanks a lot.
sokudo88
11-30-2011 07:21 AM
theguy22
11-09-2011 05:11 AM
marcos09
12-26-2009 12:22 PM
+honda_monkey+
07-06-2009 01:50 AM
Hammett
16
12-13-2001 12:52 PM
Quick Reply: GSR seats
