GSR seats
Crazy Honda Guy
Re: GSR seats
All 94+ integra seats have 3 bolts that line up, the inner rear does not. Simply swapping your stock inner rail for each seat makes this a direct bolt in. There are many threads that cover this subject
Re: GSR seats
i recently did this...
yes only 3 bolts line up. also what alot of places dont tell you is that if you only swap in the inner rails your seat will lean... its super easy to fix though. just swap the whole inner rail and for the outer side just swap in the slider part. there should be 3 bolts holding it in place. ill admit its confusing at first but after that it took me like 5 mins for the other seat.
Re: GSR seats
So then would si seats fit and into an integra if I just change the rail? What I'm trying to do is get some GSR seats and give my brother some custom made civic seats. Should I just swap rails for both seats and then plug and play? help thanks a lot.
