GSR rear swaybar on 6th gen civic ex?
i was going to grab a 14mm GSR instead of the ITR swaybar.. its coming with gsr endlinks, brackets and bushings
Will this go on the same way as the ITR anti-sway? do i just need Si endlinks or do i need the Beaks reinforcement kit? i'm assuming i don't because its close to the same size as the Si sway right?
thanks
thanks
Re: GSR rear swaybar on 6th gen civic ex? (Synthesis)
I do not know if bolts right up or not. However you shouldn't need a beaks kit for it. The Si rear sway is 13mm.
anybody tried this? maybe i would be better off with an Si rear sway. i still have stock suspension btw but will change that out this spring.
i did a search and somebody said the 99 si rear sway is 15mm, and 00 is 13mm... is this true?
The gsr sway bar will not work with the Si endlinks. I tried this on my girl's car, and could not install them. Better off with a Si sway bar.
did you guys notice an improvement? i was thinking the ITR swaybar may be a bit too much for me..
anyway, i'll go with the Si bar.. thanks!
I put the SI rear sway on while I still had stock springs/struts. I felt a lot more confident when cornering and it reduced a lot of the understeer on my EX which also has a stock 22mm front bar. The car had a very nice balance for daily driving. I still had quite a bit of body roll, but I was still on stock springs.
Later I upgraded to some koni yellows w/eibach pro-kits. Yeah, I know that the shocks are overkill, but wanted to do it right the first time. Anyways, on the new suspension, I once again have understeer, but it isn't too terrible. Under hard cornering my front end will slip while the rear is completely planted, so I think that a larger rear is in order (along with better tires). Something between 17-19mm should do the trick nicely. I think that a 22mm rear bar would be serious overkill for my needs.
So overall, The SI rear sway is a great upgrade if you can fidn it cheap. I got mine for $50. Don't expect miracles, but it is well worth the money.
[Modified by kommon_sense, 4:00 PM 3/24/2003]
Re: GSR rear swaybar on 6th gen civic ex? (kommon_sense)
SI rear is nice , but will be upgrading to competch rear 23mm sway bar which doesnt required the beaks kit .
plus im running on the front also SI 26mm which should be a nice combo
thanks!
