Gsr parts into a d16y8?
Can I install gsr injector into a d16y8? Will it make some power cause i installed gsr throttle body into the d16y8 too? After i put the gsr throttle my car is alot stronger cause the gsr throttle is bigger than my stock ex throttle plus gsr fuel filter. What other gsr parts can I install?
Ek Forever y0!
Re: Gsr parts into a d16y8? (team 15)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by team 15 »</TD></TR><TR><TD CLASS="quote">I already have a jrs supercharger for my d16y8, but don't want to install it yet. </TD></TR></TABLE>
Let me guess, you got a supercharger to be different?
You can't just add more fuel and get power, it doesn't work that way.
I suggest you grab an encyclopedia and look up "internal combustion engines"
Once you've read that, then get back to me.
if i remember, the gsr has 240cc injectors... the d16y8 also has 240s...
that throttle body that you swapped most likely did very little for your performance, and the fuel filter .... lol typical placebo effect. hmmm how about you just buy a gsr engine swap?
Ek Forever y0!
Re: Gsr parts into a d16y8? (hatchnideas)
I agree, The throttle body being bigger will probably help a little with throttle response, but nothing to write home about.
And I forgot, I think the injectors are the same size too. Small engine is a small engine
MIBPreacher
11-06-2012 08:27 AM
