GSR master and booster swap?
anyone know anything about this? i hear it is a direct bolt on to an EG hatch dx, and i hear others that say it won't work, and to get an RS one...
i scored the gsr master and booster combined for 50 bucks, so i'd like to use this if at all possible.
anyone have a pointer?
Re: GSR master and booster swap? (pissedoffsol)
also, this will be going on a wilwood 4-piston 11" front end and 11" rear disc (with weaker pads/oem-style calipers) in the rear.
is the 91 ex master/stock booster the way to do this?
or should i try to get this to work with the gsr stuff i have?
same as this
https://honda-tech.com/zerothread?id=818263
Worst case, you need to change the fitting size at the mc to abs ones and reflare the hardline = not hard.
If there isnt anything wrong with the dc unit, Id use it. I mean, you already own it...
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pissedoffsol »</TD></TR><TR><TD CLASS="quote">is the 91 ex master/stock booster the way to do this?
or should i try to get this to work with the gsr stuff i have?</TD></TR></TABLE>
The Integra MC and booster will work. The only difference vs. the '90-91 EX MC is that you'll have to re-flare one of the lines to use the Integra MC. You also need to swap the booster, so that'll be a bit more work than just swapping the MC.
Since you already have the Integra stuff, I'd just work with that . . . unless you really want to spend more money to pick up a '90-91 EX MC.
Re: GSR master and booster swap? (Targa250R)
i'm not too concerned about the money... i can always sell the gsr master/booster that i have anyway. i just want it to work....
reflaring hardlines is not appealing to me-- i wouldn't even know where to begin, and probably end up kinking the line.
what about the wilwood 1" master.
http://cgi.ebay.com/ebaymotors...&rd=1
it looks like the ports are on the fender-side of the unit... look close? anyone use this?
If you use a spring type bender you wont have any problems
Hell, I did most of my work by hand. You just need to be careful.
There is also a reflaring how-to link in the mc/bb how-to I wrote.....somewhere on there anyways.
If the wilwood piece has them on the outside you'll still have to bend the lines.
Re: (pdiggitydogg)
bah, that looks way too hard. lol
i think im going for the 91 ex jobber... see hwo that does.
if not, then i'll fight with the 1"
thanks for the help
thanks for the help
Re: (pissedoffsol)
just ordered a remanu from autozone...
autozone part number is M52517
45 bucks plus 45 for the core... under 100 shipped 1-day (local store didin't have it in stock anyway). can't complain. i can off my gsr set up for 50 bucks im sure... so i come out even
the more i think about it, the more i think im going to keep my stock 4030 ppv in there.... my rear brakes are pretty strong-- probably over kill. i have a DA 4040, but i don't think im going to put it on... give my fronts more juice.
thoughts?
thoughts?
Re: (pissedoffsol)
Wondered if someone could help me out real quick. I have my brake swap almost done. 1" GSR into 92 civic CX. all i have left to do is to put the 40/40 prop vlave in and bend and re-flare the one line with the larger fitting. What i need to know is which line do i bend and re-flare. in which position does it attatch to the prop vlave?
Thank You
Thank You
Re: (pissedoffsol)
Not totally true certain years of the GS and GSR (at least in canada) are 1" they just have a smaller resivor. I think the 95 Legend has the same Acura part number as a type R MC. If not 95 one of those years, but it had to be the manual version. As for the flaring its pretty obvious your old fitting will be to small. I just did a Type R MC booster swap in my EG. Went smooth.
LSegHatchy
03-14-2006 04:46 AM
DEIVIONCRX
02-10-2006 10:21 PM
AzntaggeR
02-14-2004 02:09 AM
