Gsr fronts brakes on EG
I just swapped gsr fronts and some ss lines on my eg. And the pedal travels way further then before. I bleed the hell out of them. Do I need a new m/c?
Re: Gsr fronts brakes on EG (eg6si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6si »</TD></TR><TR><TD CLASS="quote">you need a civic ex or integra m/c and a 30/30 or 30/40 or 40/40 prop valve.</TD></TR></TABLE>
That's odd, I did a similar brake swap in front as well as a rear disc swap on my hatch and did not need any of those things. My pedal travel feels fine. Are you sure you bled the brakes properly?
Also, I just recently read you should not hold the pedal all the way to the floor when bleeding, because it can dislodge foriegn matter into the system.
Re: Gsr fronts brakes on EG (B18C2_sedan)
well, i will do the brakes in a couple of days and i can tell u after when i got it done.
i just bought a whole set of GSR brakes. I m already running on GSR rear but still stock cx front
just bought some GSR front now, but i m not going to use the calipers and rotors.
Just also bought some ITR calipers and rotors and will bolt onto the GSR knuckle. Hope it works and not have the long travel either!
Re: Gsr fronts brakes on EG (rodrez)
bleed them with the car running. i tried bleeding with the car off for about 2 hours and they lines still had air in them. bled the brakes with the car on and the air was out of the lines in 15 mins
I say buy the integra mc and booster. When I had gsr fronts on my eg si, I DIdnt like it at first but I became a cheap *** and didnt want to buy the mc and booster so I just got used to it.
thanks for all the help. I got a 91 ex 4 door m/c on order. And after driving around for a few days my brakes have gotten better. could by just the pads breaking in. By the way I have a lx.
RuckRider2
05-03-2017 03:31 PM
splickitysplat
03-11-2009 08:21 AM
