GSR Calipers
I've already done a search and found what was required to mount GSR calipers on my non-abs eg cx. What I want to know now is if it's worth it or not. What other braking upgrades should I be looking at instead? Post some opinions, I'm thinking of picking up some Monday.
its quite a bit of a braking difference over the small hatch brakes, apparently.
Another option is a larger booster/mc combo to stiffen up the pedal feel. |
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">
Another option is a larger booster/mc combo to stiffen up the pedal feel.</TD></TR></TABLE> But your braking will still be shit. I would try to find the whole knuckle, it will save you a lot of trouble, but if you think you can do it and want to save the money, oem bigger brakes cant hurt. https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: (elwood)
You could always just get new rotors and a nice set of pads and some SS brakelines and a fancy brake pedal cover!
Re: (elwood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elwood »</TD></TR><TR><TD CLASS="quote">
But your braking will still be shit. </TD></TR></TABLE> I meant it as an option after the caliper swap |
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">Another option is a larger booster/mc combo to stiffen up the pedal feel.</TD></TR></TABLE>
This is going to be done anyway, hoping to pick up either teg or Si trailing arms while I'm at the junkyard. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elwood »</TD></TR><TR><TD CLASS="quote">I would try to find the whole knuckle, it will save you a lot of trouble, but if you think you can do it and want to save the money, oem bigger brakes cant hurt. </TD></TR></TABLE> Yea, I'm trying to score a set of knuckles. I heard you can use VW Corrado rotors with the teg caliper set up. They're supposed to be something like 11", anyone do this? |
Re: (SpydiR)
i found a wrecked EX at a junkyard. i think im gonna take the front knuckle off that and use those to replace my tiny brakes!!
Re: (spock_rocker)
yeah when you upgrade your cx brakes to 10.2" unit the car brakes like it's crazy. Car just stops, no brake fade nothing. Amazing improvment.
Re: (SpydiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpydiR »</TD></TR><TR><TD CLASS="quote">I heard you can use VW Corrado rotors with the teg caliper set up. They're supposed to be something like 11", anyone do this?
</TD></TR></TABLE> You minght be thinking of the prelude vtec callipers. I have heard you can use the veedub stuff but my rotors were just re drilled to 4x100. https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: GSR Calipers (SpydiR)
why would u want to put gsr calipers on ur civic? are u planning on getting gsr rotors also cause it would probably be easier to get the whole steering spindle from a salvage yard.
integra calipers are larger than civic ones...all of them. The ex/si have the same size rotor as integras
(i never understood why people say "gsr calipers" since theyre all identical -ls/gs/gsr) |
