GSR block on B16 head
Old 02-13-2003, 03:25 PM
lazy bum shaughn's Avatar
Default GSR block on B16 head
I was wondering what modifications, if any, would I hve to do to make this work. My idea is to get a full B16 swap, then get a GSR block.
Why you ask?
Well first off B16 already has a closer geared tranny, and why get bother spending more money on a GSR motor when I'm going to do headwork anyway? Hope that didn't confuse anyone.
What timing belt and oil/water pump will I have to use?
Thanks, much .
Old 02-13-2003, 03:27 PM
Future Texas Boy
vtecvoodoo's Avatar
Default Re: GSR block on B16 head (lazy bum shaughn)
How about a b20 block?
Old 02-13-2003, 03:30 PM
Default Re: GSR block on B16 head (vtecvoodoo)
Thanks for the comment. I did consider it but I rather keep it as OEM as possible, and a non VTEC block on a VTEC head doesnt seem like a good idea to me because I always hear about sleeves cracking and the block isn't meant to rev as high yadda yadda.
Old 02-13-2003, 04:48 PM
ArinX's Avatar
timing belt ud have to use a gsr/type r becasue the b16 one would be too short.
water pump oil pump either gsr or itr will work also.
everything else should bolt right up
Old 02-13-2003, 04:52 PM
zc911's Avatar
Default Re: GSR block on B16 head (ArinX)
just re,ber you get a pretty low comrpession ratio when you do that becuase of the GSRs pistons
Old 02-13-2003, 04:54 PM
Toda Party's Avatar
Default Re: GSR block on B16 head (zc911)
poor man's type-r motor
Old 02-13-2003, 05:10 PM
SIReg9's Avatar
Default Re: GSR block on B16 head (Toda Party)
Im building 1 right now... Gsr block, Ctr pistons, And a B16 head. Hope to finish up soon
Old 02-13-2003, 05:15 PM
Dancing is Forbidden's Avatar
Default Re: GSR block on B16 head (SIReg9)
Isnt there a lot of people that put the B16a head on the B18C block? Sounds like a good idea to me. Should create some nice numbers. Give it a shot.
Old 02-13-2003, 05:22 PM
Ya@inlinePRO's Avatar
Default Re: GSR block on B16 head (EF9_SiR)
sleeves crack on the b20 cause they suck. don't you mean b16 head on a gs-r block?
[Modified by kwik2nec, 9:22 PM 2/13/2003]
Old 02-14-2003, 02:56 AM
Default Re: GSR block on B16 head (kwik2nec)
Yea, after I made the post I was like wait a minute..ahh well you people know what i mean lol.
Anyway thanks for the responces. I plan on using the B16 pistons for a higher compression ratio(PR3 right?). Does the GSR block have extra sensors hanging out?
I can use my stock B16 ECU with no problems right? Or would I run lean(1.8 displacement)?
Thanks again.
Old 02-14-2003, 05:00 AM
9200RPM's Avatar
No you want Civic Type R pistons (B16b) not B16a
Old 02-14-2003, 11:09 AM
phantoman's Avatar
Default Re: GSR block on B16 head (TurboB16aEG)
i have the same set up.
gsr block, ctr piston
itr head with valve train, gsr cams.
with prelude injectors. 190 cc
everything else is stock.
CR: is 11.8:1
hspwer with gsr cams is 165 hp and 119 tq.
with vafc vtec is at 5300 rpm.
b16 head will yeild a lower compression it is aprox .3 less than the gsr head.
if you are going all motor the gsr head will be better for high compression.
i am in process of buying some ctr cams, i'll dyno it and let you guys konw what to expect with this set up.
[Modified by phantoman, 12:10 PM 2/14/2003]
Old 02-14-2003, 12:00 PM
I know that but I'm poor and the stock SI pistons will yield higher compression than GSR ones.
Thanks though.
Old 02-14-2003, 12:35 PM
Doctor CorteZ's Avatar
Default Re: GSR block on B16 head (phantoman)
wrong specs on the injectors dude.
270cc
Old 02-14-2003, 12:40 PM
blackANESE's Avatar
Any vtec oil pump/water pump will work.
Old 02-14-2003, 12:46 PM
Default Re: GSR block on B16 head (blackANESE)
Even H22?
Old 02-14-2003, 12:48 PM
Even H22?
why would you even think that would work ?
here let me spell it out for you - any B series VTEC pump will work...
Old 02-14-2003, 01:01 PM
redline201's Avatar
Default Re: GSR block on B16 head (Doctor CorteZ)
can you mill the b16 head to make up for the lost comprssion
Old 02-14-2003, 01:04 PM
Even H22?
First off I was kidding, I guess I forgot the smiley.
Second if H22 injectors will work, hmm maybe other H22 parts will?
Old 02-14-2003, 02:01 PM
couter.net's Avatar
Even H22?
He was talking about injectors
H22a injectors work
Old 02-14-2003, 07:09 PM
phantoman's Avatar
dr. cortez,
ur right, i did right the wrong spec.
but i think u got it wrong too,
type r's are 270
and H22 are 290.
if i am not mistakened.
thansk for the correction tho.!
Old 02-14-2003, 08:51 PM
sshaikh01's Avatar
i'm very sorry for a noob queston.
But whats the differnce in compression, is lower compression good or is higher compression good.
I plan on going all motor, but i don't want to go crazy on the engine too.
Old 02-14-2003, 10:23 PM
phantoman's Avatar
Default Re: GSR block on B16 head (sshaikh01)
higher compression is better for allmotor.
i would say a safe compression on pump gas, octan 91 or 93
would be anywhere from stock - 11.8
closer to 12.1 cr is risky.
this is all my opinion. i think other feel that this may be too high or not high enough
Old 02-14-2003, 11:22 PM
SpoolinSol's Avatar
dr. cortez,
type r's are 270
and H22 are 290.
Type R injectors are 240cc
Prelude injectors are 280cc
Old 02-14-2003, 11:58 PM
acydphryck's Avatar
b20 sleeves suck ***...b20 with sleeves...now that's a different story...
Quick Reply: GSR block on B16 head
