GSR block on B16 head
I was wondering what modifications, if any, would I hve to do to make this work. My idea is to get a full B16 swap, then get a GSR block.
Why you ask?
Well first off B16 already has a closer geared tranny, and why get bother spending more money on a GSR motor when I'm going to do headwork anyway? Hope that didn't confuse anyone.
What timing belt and oil/water pump will I have to use?
Thanks, much .
Why you ask?
Thanks, much .
Re: GSR block on B16 head (vtecvoodoo)
How about a b20 block?
Re: GSR block on B16 head (lazy bum shaughn)
timing belt ud have to use a gsr/type r becasue the b16 one would be too short.
water pump oil pump either gsr or itr will work also.
everything else should bolt right up
Re: GSR block on B16 head (SIReg9)
Isnt there a lot of people that put the B16a head on the B18C block? Sounds like a good idea to me. Should create some nice numbers. Give it a shot.
Re: GSR block on B16 head (kwik2nec)
sleeves crack on the b20 cause they suck. don't you mean b16 head on a gs-r block?
[Modified by kwik2nec, 9:22 PM 2/13/2003]
Anyway thanks for the responces. I plan on using the B16 pistons for a higher compression ratio(PR3 right?). Does the GSR block have extra sensors hanging out?
I can use my stock B16 ECU with no problems right? Or would I run lean(1.8 displacement)?
Thanks again.
Re: GSR block on B16 head (TurboB16aEG)
i have the same set up.
gsr block, ctr piston
itr head with valve train, gsr cams.
with prelude injectors. 190 cc
everything else is stock.
CR: is 11.8:1
hspwer with gsr cams is 165 hp and 119 tq.
with vafc vtec is at 5300 rpm.
b16 head will yeild a lower compression it is aprox .3 less than the gsr head.
if you are going all motor the gsr head will be better for high compression.
i am in process of buying some ctr cams, i'll dyno it and let you guys konw what to expect with this set up.
[Modified by phantoman, 12:10 PM 2/14/2003]
CR: is 11.8:1
No you want Civic Type R pistons (B16b) not B16a
Thanks though.
Even H22?
here let me spell it out for you - any B series VTEC pump will work...
Re: GSR block on B16 head (Doctor CorteZ)
Even H22?
why would you even think that would work ?
Second if H22 injectors will work, hmm maybe other H22 parts will?
Even H22?
H22a injectors work
dr. cortez,
ur right, i did right the wrong spec.
but i think u got it wrong too,
type r's are 270
and H22 are 290.
if i am not mistakened.
thansk for the correction tho.!
type r's are 270
and H22 are 290.
i'm very sorry for a noob queston.
But whats the differnce in compression, is lower compression good or is higher compression good.
I plan on going all motor, but i don't want to go crazy on the engine too.
Re: GSR block on B16 head (sshaikh01)
higher compression is better for allmotor.
i would say a safe compression on pump gas, octan 91 or 93
would be anywhere from stock - 11.8
closer to 12.1 cr is risky.
this is all my opinion. i think other feel that this may be too high or not high enough
Re: GSR block on B16 head (phantoman)
dr. cortez,
type r's are 270
and H22 are 290.
type r's are 270
and H22 are 290.
Type R injectors are 240cc
Prelude injectors are 280cc
