got integra radiator.. now how do I make it fit
ok so I bought a radiator off of a 94 integra to replace the small one in my civic, and of course, I have no clue how to make it fit... if it even will. so can anyone give me any ideas as to how I can use it, if I can?
Re: got integra radiator.. now how do I make it fit (metroya_perform)
it does fit. But will require you to remove your old radiator and condenser mounts and have them rewelded for the integra mounts. Then for the upper mounts you can use accord or integra mounts.
more about it:
http://www.hybrid.honda-perf.o....html
more about it:
that actually helps. the problem is, I dont have access to a welder, or anyone who can weld, so yea, anyone in the area want a radiator?
Re: (metroya_perform)
there is another way... remove the old mounts. Hit up home depot get some brackets that will work with bottom of the radiator. Then drill and screw in new brackets.
it will be much easyer to install the delsol,just bolt it up. you could temp.install the teg then take it to a shop and have it welded.
lsvtec101
11-19-2003 08:13 AM
