GOD HATES ME (windows not working)
Dat Dere Cell Tech
My power windows, EVERY switch, is not working. NEither is the sunroof. What could be the cause of ALL FOUR switches not working ? cause im at a loos. i checkd the in-car fuses and theyre all A-OK. I was hooking up my tach and some other gauges and when i was all done i got ready to go to work then BLAM they dont roll up. ITs about to rain so i need help ASAP
hm, sounds like you hooked up the tach and guages wrong or something. where did you wire them up to? where did you get your power from? and most important, where are the grounds.
theres got to be a fuse somewhere that you blew, check the ones labled backup too, i know that sounds stupid but the underhood fuse labled backup actually goes to the ecu and stereo....
i couldnt figure out why the **** my stereo wouldnt work, FOR ALMOST A YEAR....all because that damn underhood fuse is labled backup.
Dat Dere Cell Tech
backup fuse was blown, so i replaced with a 20 amp and nothing happend, then checked and its still blown. Its got to be something that will affect ALL FOUR. (sunroof and 3 window switches.)
Re: (daklown)
i lent my car out one day got it back and the CEL was on. 3 codes speed sensor o2 senor and ELD electronic load dectecter. honda couldnt even tell me what it was. for a 3 months drove with no vtec or speedometer. check my fuses because my radio wasnt working right found a broken one replace it and son of a bitch no more CEL. all becuase a ****** fuse.
if you replace a fuse and it blows again u definately fucked up sum wiring :/ put a circuit breaker in there, thats what the mechanic did in my car when my windshieldwiper/sunroof fuse kept blowing.
im not sure if circuit breaker is the thing im thinking of... its a little silver box.....sumone here must know what im talking about and more about it, i dont know crap bout wiring
Dat Dere Cell Tech
it didnt blow the second fuse. it jsuts didnt fix anything. The Tachometer and Voltemeter are hooked up the Radio fuse for power, and they radio tach and voltemeter were all working fine, just the windows and sunroof are pwned.
