HELP no amps work??
Old Jul 6, 2006 | 07:55 PM
ph0shizzle's Avatar
Default HELP no amps work??
hey my amps always been workin and i tried many diff kinds. im 100% sure the wires are hookd up correctly because i use to bump in my car. but recently i changed amps and i forgot to disconnect the negative battery and when i was takin out one of the wires (dont know if it was ground or power) it created a spark. now none of my amps work. what could be wrong? please HELP
Old Jul 6, 2006 | 08:50 PM
nsxxtreme's Avatar
Default Re: HELP no amps work?? (ph0shizzle)
you probably blew the remote on the deck. Some are fused check the remote wire for a fuse.
Get a volt meter and test for power at the remote wire.
Old Jul 6, 2006 | 10:17 PM
02 accord's Avatar
Sounds like you blew the fuse on the power wire going to your amps.
Old Jul 6, 2006 | 11:06 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: HELP no amps work?? (02 accord)
You need to check all of your fuses, it sound like a power fuse, Take xtreme advice and go thru everything, If all else fails give suspendedHatch a i.m. He is local to you and he might be able to look at it for you. He is a stand up guy.
Old Jul 6, 2006 | 11:48 PM
ph0shizzle's Avatar
Default Re: HELP no amps work?? (wrx-killer-Sti eater)
damn thanks. i found the problem. my power wire fuse was blown =X sucks that it was the LAST fuse i checkd :/, i checkd all my fuses next to my battery then my amps first when it was the power wire fuse . haha aiites well thanks for all your helps.
Old Jul 7, 2006 | 01:34 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ph0shizzle &raquo;</TD></TR><TR><TD CLASS="quote">damn thanks. i found the problem. my power wire fuse was blown =X sucks that it was the LAST fuse i checkd :/, i checkd all my fuses next to my battery then my amps first when it was the power wire fuse . haha aiites well thanks for all your helps. </TD></TR></TABLE>
That should have been the FIRST thing you checked.
-Championship-
Audio / Security / Video
Nov 2, 2006 01:22 PM
highneo
Jan 9, 2006 11:54 AM
9500redline
Oct 28, 2005 06:25 PM
Understeer
Aug 23, 2002 03:04 PM
