gm synchromesh or gm mtf?
ive read many topics about what transmission fluid to use. everyone says gm is the best stuff to buy to get rid of high rpm grinds. but i talked to the guy at the gm place and he said the sychromesh is for automatics. isnt that bad to put in a manual transmission? is there some important piece of information i am not aware of yet? i bought the mtf because i dont want to stick automatic transmission fluid in. and if that were the case i wouldve just bought the pennzoil atf cause its the exact same stuff as the gm but cheaper. did i buy the right tranny fluid or do i need to back and return it for the gm sychromesh?
Re: gm synchromesh or gm mtf? (rtiadnoh)
You should probably read some more...
Use Honda MTF for Honda Manual Trannys and Honda ATF for Honda Auto Trannys. That's the general consensus from my research.
Re: gm synchromesh or gm mtf? (axhandler)
ive seen this big *** gm synchromesh thread.
You have to search for it here
https://honda-tech.com/zerosearch
Re: gm synchromesh or gm mtf? (JMS JT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JMS JT »</TD></TR><TR><TD CLASS="quote">GM Synchromesh FRICTION MODIFIED.</TD></TR></TABLE>
Just changed mine with this on Friday. It just started working today and MAN is it smooth. Butta' smooth! <U>FRICTION MODIFIED</U>
doubleoazn03
64
01-08-2018 11:54 AM
