JDM B20 Reliability vs USDM B20 Reliability
Re: JDM B20 Reliability vs USDM B20 Reliability (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad »</TD></TR><TR><TD CLASS="quote">THEY ARE THE SAME!!!!!!!!!!
Moderator
Re: (Mr.E.G.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.E.G. »</TD></TR><TR><TD CLASS="quote">shitty cylinder walls. \ </TD></TR></TABLE>
once again someone who HAS NO CLUE!!!
this is NOT TRUE.....i'm at 220 hp on stock b20 sleeves....have torn it down now 3 times and they show no unusual wear....
yes the sleeves are not as strong if you are boosting....
Re: (aemcivic_02917)
There is no reliability difference between the two. However, earlier b20's had lower compressoin and made slightly less power than the 99-01 b20's. Just FYI incase your buying one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aemcivic_02917 »</TD></TR><TR><TD CLASS="quote">ya but the long stroke is a killer i try to keep my revs down but sometimes (alot) i get lead foot ha ha ha</TD></TR></TABLE>
how high have you been revving it?
Moderator
where do you come up with this crap.....
rev'd mine to 8500 all the time!!!!
Re: (SICKSOLVTEC-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SICKSOLVTEC-T »</TD></TR><TR><TD CLASS="quote">What kind of cams do you have on your b20 that your making power at 8500?</TD></TR></TABLE>
i would like to know that too
Re: (Mr.E.G.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.E.G. »</TD></TR><TR><TD CLASS="quote">i ahev jdm in my car and us on my engine stand both suck. shitty cylinder walls. if you can get it sleeved or posted then that is the only way to to go </TD></TR></TABLE>
i agree. the monolithic design lends itself to heat spots which in turn end up cracking the sleeves. I've yet to see this on a n/a b20 though, usually someone will have a spun bearing from revving too high before they make enough power to cause the heat spots
Moderator
Re: (SICKSOLVTEC-T)
STOCK BOTTOMEND....b20z
TODA B's....power was made to 8500 ON STOCK ROD BOLTS!!!
38000 miles before i wanted more power
185 hp 142 tq on a dynapak dyno.....
