Gauge Cluster, Turn Signals, Clock wont work.
Old 08-31-2009, 04:04 PM
  #26
Former User's Avatar
Default Re: Gauge Cluster, Turn Signals, Clock wont work.
Originally Posted by jOnW89
A3 is a solid yellow wire with silver spots in some places no power goes to this wire.
This is your problem. The Yel wire at A3 in the cluster connector should have battery voltage with the key in ON(II). So the problem could be a broken Yel wire somewhere between the cluster and dash fuse box or a bad dash fuse box. Try to locate the same Yel wire coming from the rear of the dash fuse box and then scrape away a little insulation to see whether it has battery voltage close to the dash fuse box with the key in ON(II).
Old 08-31-2009, 04:10 PM
  #27
jOnW89's Avatar
Could I run power to it off another wire that gets power with key on(2)? To make my life easier for now I really hate running out of gas lol.
Old 08-31-2009, 06:10 PM
  #28
Personally, I would invest a little bit of time trying to locate the problem because in the end this could save you some rewiring time.
Old 08-31-2009, 06:32 PM
  #29
jOnW89's Avatar
I traced the wire for a little all looks intact I just don't understand what could have happen? I also notice this same color wire goes to the clock as well. Is there anything else this power wire goes to that I should be aware of my turn signals also don't work but I'm assuming that's because there is no power going to the cluster.
Old 08-31-2009, 06:41 PM
  #30
See post #7 for all functions on the Yel wire circuit. Use your voltmeter not vision to pinpoint where voltage can and then cannot be detected on the Yel wire. The problem will be found between those two points. Start the voltage test as close to the dash fuse box as possible.
Old 12-18-2009, 02:16 PM
  #31
morganm58's Avatar
did you ever solve the problem? because the same thing is happening to my integra da
Old 01-29-2010, 05:53 AM
  #32
ikiyu's Avatar
Anyone figure this out?
Old 02-01-2010, 04:05 PM
  #33
morganm58's Avatar
i fixed my problem. it was fuse 23 and a next fuse. they where burning out each other for some reason
Old 02-20-2010, 04:03 PM
  #34
New User
vossque's Avatar
I just purchased an 88 civic hatchback. On the first drive home (200+ mile trip), the clock, turn signals, and gauges all shut off. After awhile, they turned back on and have been occassionally coming on and off every day till the point where they don't turn on at all anymore. At one point, the headlights were flicker on and off when I ran over bumps and sometimes the high beams would turn on and off as well.
Well, today I got some time to look at it and it was simply a blown fuse. For me this was my fuse no. 1. It cost me 1 dollar, and it is all fixed. I don't know if this is the case for everyone else, but wouldn't hurt to replace the fuse, especially if you can get it for a dollar!
Perez_cb7
07-23-2013 10:32 AM
90CRXZCSI16
10
02-01-2013 12:11 PM
riceboy
03-21-2005 01:07 AM
SiR HatchAlot
03-28-2004 09:31 AM
BoostedSi
02-23-2003 08:59 PM
Quick Reply: Gauge Cluster, Turn Signals, Clock wont work.
