gauge cluster
gauge cluster
I have a dx gauge cluster...where and how much is a ex or si gauge cluster or something that has a tach...I don't like the jdm white faced, otherwise I'd get that....any help
Re: gauge cluster (citrusdrop)
white faces...so i assume 5th gen
check ebay...there should be several on there...if not call a local junk yard or salvage yard
got mine for 150 bux from member "SKUNK2UNERZ"
Wired right up, even swaped the speedo to keep the miles. Works perfect. TAKE YOUR TIME REMOVING THE DASH PART! it's soft plastic and will scratch/break easy!
Good Luck i just did this last week if you need any help let me know!
-Sketch
P.S. SKUNK2UNERZ you ******* rock!
-Sketch
Re: (Sketch_hs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sketch_hs »</TD></TR><TR><TD CLASS="quote">got mine for 150 bux from member "SKUNK2UNERZ"
-Sketch
P.S. SKUNK2UNERZ you ******* rock!</TD></TR></TABLE>
Just like he said just got one from him. 2 days after I paypaled him. Couldn't have worked better I got a auto one just cause they were a ton cheaper. Plug and play you won't get one off ebay even USDM for as cheap as you can get on here from other members. Check skunk out last I knew he had one auto tach one left. It works just the same!
-Sketch
Location: Toronto, Canada currently residing in ATL, GA, USA
Re: (dantastic)
Sold my cluster for 30 bux (Speedo stopped working). Buyer plugged his DX speedo into it.....worked like a charm.
Bought the JDM EG6 cluster, climate control, clock, and rear defroster switch for the same price a brand new USDM speedo would've cost me.
etp72
06-12-2003 05:51 PM
