Gas Mileage
Gas Mileage
I'm getting my swap this weekend, im gonna build a D16Y8 for boost (Pistons, Rods, Bearings, Gaskets, Studs, etc) Im thinking of running somewhere between 10-16 PSI. What kind of gas mileage can I expect to get, because I am going to daily drive this car.
Re: Gas Mileage (Jimster480)
Pretty much the same as you would if it were stock. The only time you are gonna use more gas is when you are getin on it
Re: Gas Mileage (h-duced)
oh really, thats good. My friend is like oh ur gonna get like 10mpg. And i thought that just sounded too low so ya.
It also depends on how you tune your car. If you lean it out all the way you'll either keep the same MPG or even gain some more. Some people rather go the safer way and force it to run rich therefore causing them to lose some MPG compare to stock MPG.
Re: (lv6l)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lv6l »</TD></TR><TR><TD CLASS="quote">It also depends on how you tune your car. If you lean it out all the way you'll either keep the same MPG or even gain some more. Some people rather go the safer way and force it to run rich therefore causing them to lose some MPG compare to stock MPG.</TD></TR></TABLE>
I understand, but its not gonna be like 10mpg even if i run it pretty rich right?
Re: (Jimster480)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimster480 »</TD></TR><TR><TD CLASS="quote">
I understand, but its not gonna be like 10mpg even if i run it pretty rich right?</TD></TR></TABLE>
Most of the time yes, you will never lose that much mpg. Only time you will need more fuel than average is when you are putting more pressure into your cylinder. But then again, a tuner can make one wrong move and rich out the whole RPM band which will force your car to run rich all the time; despite boosting or not. But if a tuner does that he is either making sure you don't blow a hole in your motor or he is plain retarded.
Re: (-iLLuZioN-B18C1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -iLLuZioN-B18C1 »</TD></TR><TR><TD CLASS="quote">youre gonna get lower mpg's b/c youre gonna always be on it </TD></TR></TABLE>
I'm sure there's plenty of truth to that lol
Re: (devney)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by devney »</TD></TR><TR><TD CLASS="quote">
I'm sure there's plenty of truth to that lol</TD></TR></TABLE>
lol ill have to fight the temptation to drive fast XD
djdownfawl
Honda Civic (2001 - 2005)
13
03-23-2008 07:57 PM
Killer_B
07-08-2004 08:20 PM
