g-tech ?
g-tech ?
Ok I know alot of you think its crap but right now until I get to a track it is all I have. So if you have ever used one let me know because I just started using one my friend gave me tonight. I got the following times when I did three runs by my house.
16.03
15.94
14.97
This is on 93 honda civic coupe ex with the suspension below and a home made air intake...all i have done for weight reduction is to remove the **** in the trunk...so the trunk is empty...i think the first 2 are realistic...but the last one is that possible with my setup?
Thanks in advance
DEF
16.03
15.94
14.97
Thanks in advance
DEF
Former Moderator
Re: g-tech ? (deftones0817)
Yeah man the GTech just is not consistent enough to rely on.
When you get the chance just try and take it to the strip.
Re: g-tech ? (couter)
i know wut u mean bro. track is closing soon for winter. but it doesn't look like the gtech was off much on the first 2. those are the exact numbers i have seen w/ ur set up. the last one makes u look real fast though... hehe
Re: g-tech ? (ill phil)
wow a 1.06 sec drop with the same setup. i think your g-tech is
edit: you got to tell me your secret!!
[Modified by pennies_hatchie, 10:29 AM 11/20/2002]
When using your G-Tech you have to make sure the road is flat. Just hitting a bump will throw it off. The most important thing is make sure it is "Zeroed" out (0.00) before it flashes --GO-- otherwise will get another untrue reading. With ideal conditions it should be accurate to at least 1/10th of a second.
Re: g-tech ? (ZC_CRX)
You guys need to stop I was just saying that I thought the first 2 were correct the last one I did launch way better...so I was just wondering I'm going to try to do 10 more runs and get an average...I know the civic should run 16.8 around there on a stock setup...so I figured the first 2 were cool and the last one was off...is it possible to reach low 15 or high 14 with good launches with this setup? I'm new at racing and like I said the track here is closed already so please just is it possible or no..but from what you said I guess no unless your just being dumb?
DEF
DEF
dosplunder
26
03-22-2010 06:46 PM
Attoir
22
05-03-2003 11:20 PM
