fuel pump bad?
fuel pump bad?
i need help.. my car keeps shutting off like it runs outta gas..
i pull over and recrank it.. itll run.. but itll keep doin it..
itll run fine for a whileif he engine is cold..
idk if the fuel pump is goin out.. i hear the pump run.. no cells. noother problems.. what culd it be?
Re: fuel pump bad?
i also jus installed a new coil.. faulty coil maybe? i replaced it cuz i get poorlow end power.. ran fine with another dizzy i had.. but i no longer have it
Re: fuel pump bad?
yea i got a cheap coil off ebay..
and like 2 days later it started doin this..
can a fuel pump occasianally work?
ima try using the old coil in the morning and see if this helps..
Re: fuel pump bad?
yeaill have it tested.. im sure this must be the problem..
cuz my low end power sucks really bad.. itll die downon the smallest of hills..
and the timing is spot on..
i also have to run my dizzy fully advanced..
its not off a tooth..
i had this problem b4 the rebuild
NovaRex
12-04-2015 05:10 PM
classdork987654
01-01-2009 01:16 AM
