Fuel pump? "no start" problem
I have a 96 EK dx with a sir b16 swap in it. right this second it's engine turning, not starting. I checked for spark and I have it. I listened for the fuel pump priming ("whirrr" noise) and it doesn't sound anything like I remember it was supposed to sound. It's making more like an electrical connection is being made coming from the backseat (clicking almost). Is it more than likely the fuel pump? Any constructive input is greatly appreciated. Thanks
check for fuel at the fuel filter and if u do have fuel then its not ur pump..if not then jump the pump to the postive post of the battery and fuel should be comming out.. im also doin the exact same swap at you are..are you runnin a OBD1 or OBD2 dizzy??
Hey, thanks everyone for your replies. I checked all your sugestions tonight. There wasn't any fuel pressure. I took out my back seat and jumped the pump with no change, it makes the same noise, so I'm guessing that the pump's the culprit. I ordered a walbro 255lph that should be coming inthis week. I'll post if it fixes the problem. Thanks again...
ekb16- If I could give you the best advice possible it would be to use your stock wiring harness with the conversion harness to obd1, you can buy them for like 80 bucks. I thought I'd be "mr. do-it-yourself" and make my own harness conversion. Although I did it successfully, it was the biggest headache. Good luck, hit me up if you have any more questions.
ive done all my wireing already..i ran all the wires n stuff to my obd1 ecu already but my dizzy is obd2 and my injectors are obd2...i was told i could use them so i did and bought a brand new obd2 gsr dizzy...i dont have time rite now but when i get the chance imma do the obd2-obd1 dizzy conversion and see if my car starts after that..
O16581724 5 2 5
07-06-2006 06:45 AM
Eluzion
04-11-2004 09:51 PM
