Fuel Pressure Regulator w/ Hondata
i just bought a hondata s100b system and i was wondering what my fuel pressure should be at or what i would like to see it at ( i have a B&M gauge that im going to install today)
im running 15psi on a fully built d16y8 motor
thanks
thanks
Re: Fuel Pressure Regulator w/ Hondata (jeffb006)
I also just bought hondata s200b and have a weapon r fuel regulator , can I use this and what pressure is it supposed to be at. Not sure on what regulator hes using though figure its the same type as mines.
Re: (fishnfst)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fishnfst »</TD></TR><TR><TD CLASS="quote">50 psi is normally a good starting point. When you have your tuner redo your basemaps he can adjust the fuel pressure accordingly</TD></TR></TABLE>
50psi? why 50?
Stock is more then enough, 32-38psi is plenty, no need to run more psi then required.
50psi? why 50?
ATgrills.com
07-24-2003 07:38 AM
