fuel into filter, but not out (on swap)
I'M DOING A MOTOR SWAP AND TRYING TO START IT UP NOW. FUEL IS GOING TO THE filter but its not coming out at all. I took off the exit line to fuel rail and nothing happened. I took off hte nut AT the fuel rail and still nothing happened. But when i take off the line going IN TO the filter, gas spews out.
what gives??
what gives??
Re: fuel into filter, but not out (elmalouno)
undo the line from the filter to the fuel rail and turn the ignition from I to II a few times to run the fuel pump, then check to see if fuel is coming out
Re: (elmalouno)
can someone try and explain how the FPR ties in to this? is it a vaccum system or is the only force getting the fuel to the rail the fuel pump?
moonpieboy
10-09-2005 09:57 AM
