fuel injectors not firing
im getting fuel and spark but for some reason im not getting gas past the injectors, im really lost i tried cleaning all the ground and the the thermostat ground, tried switching with a known working ecu and main relay, i even switch the engine harness and body harness. yes the motor works this is the third motor i tried and still nothing can someone help me out
Im getting fuel to the rail no problem but not coming past injectors. Half tank showing and a fuel filter replaced about 4 months ago.
Im going to try and test injector signal tomorrow.
Is it just a case of putting a multi-meter to the clips or is there a specific way to test as this is not something i've had to do before.
Any help would be great!
this happened to me before. i ran power across each injector individually to see if i heard a click. two of them did not click. i replaced the two and it started up instantly. if your getting power to the injectors at the harness and checked to see if they click when energized with 12volts across contacts. then i would think it may be ecu related since the ecu is what grounds out the injectors
i dont remeber what the ecu use to fire the injectors there has to be some kind of input. it maybe something in the distrubtor if i remeber right. if you have a spare distrubtor you may wana try to swap that out. but im not really sure about that tho
iperez
Feb 19, 2003 09:05 AM
