Fuel Injectors for NA CRVtec?
Ive been hearing 310cc injectors should cut it, but im having problems find a 310cc injector.
I do eventually plan to do headwork and such, but the 440cc Injectors are for
250whp at the stock fuel pressure of 40lb.
RC 440cc injectors too much?
Re: Fuel Injectors for NA CRVtec? (b20eg6)
probally and go here www.importparts.com they have the 310cc
1 Post
if your street driving it, the stock injectors would be fine. You dont need the RC 310's yet unless your doing over 210hp. even at that, its not super important yet.
310s would be the most on the street and is sufficient enough to handle for the NA route.
Wil
Wil
Re: Fuel Injectors for NA CRVtec? (infamousRRH)
440s are way to big unless you are using a stand alone ecu, or vafc...you won't even get them to idle....
310 should be fine for an NA application...
I have them for 305 shipped.
I would even suggest RC 270cc injectors...310 is sufficient as well but only if your going past 210whp...You can find them just about anywhere though...good luck.
SuperDragII?
That was your question
305 For what type (as in resistance) of injector?
thanks
thanks
Re: Fuel Injectors for NA CRVtec? (SuperDragII)
you've got mail...i'm interesetd in ur 310cc injectors for $305.00
are they obd 1 or obd 2 are they pead & Hold or saturated...new/used?
Thanks.
vnt
Thanks.
vnt
ATS*Mark
08-18-2004 09:16 PM
