Fuel gauge problem ! Plz help !!!
I did search and found nothing.
Fuel level is always full, I even tried to adjust the needle (unplug the cluster, adjust the needle to E) but it went all the way up again and stay there 4ever.
Help me please !!! Thank you !
Re: (zyzyx6969)
If it reads just at full, it might be the sending unit or guage. If it reads unusualy past full it is usually a bad ground to the sending unit (floaty thing) Good Luck
Re: Fuel gauge problem ! Plz help !!! (zyzyx6969)
test it..
take off your rear seat.. disconnect the wires going into the connector on the fuel pump / sending unit cover. and see if the gauge goes down.. if so then you have a bad float (which is part of the sending unit for the fuel gauge)
sidewayz
09-22-2013 09:28 AM
